Fluent on NT or Linux
Old   February 16, 2000, 11:19
Default Fluent on NT or Linux
Arturo Ortiz
Hi, I am in the process of selecting a platform for Fluent. My possibilities are NT or Linux, but I am not sure which one is better. I'll thank any comments regarding this subject. Regards
Old   February 17, 2000, 11:19
Default Re: Fluent on NT or Linux
Aaron J. Bird
I would suggest Linux since its basically free. You will also have the ability to go parallel much easier if you are able to get several boxes. And consider that you can get a gnu fortran for it too. HOWEVER, Linux isn't supported like microsoft products so if you have problems with it, then more than likely you're stuck with them. On the other hand- will also have a lot less stuff going on with Linux, so your ram isn't going to get sucked up like it does with nt... or 2000 if you're considering going that route. Linux is solid. We're using it for a raid storage, and I just learned yesterday that we're finally going to construct the cluster we've been talking about for some time now, so I'm happy about that...
Which Linux Distro for OpenFOAM and Fluent jason.ryon OpenFOAM 9 December 8, 2010 18:31
Fluent on Linux Shamoon Jamshed FLUENT 11 September 7, 2010 13:55
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 10:49
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 02:05
Linux optimization for FLUENT Jacek FLUENT 9 May 23, 2002 03:11
