[ASK] Flow in Corrugated Pipe with FLUENT
Old   February 7, 2011, 09:00
Default [ASK] Flow in Corrugated Pipe with FLUENT
Primadhani's Avatar
Rizqi Primadhani
Primadhani is on a distinguished road
Send a message via Skype™ to Primadhani
Hi Friends,
I'm a student and now i'm studying about flow in pipe (internal flow) with CFD. I have a case about corrugated pipe, it looks like this:
It's a 2D case, fluid flow from left of the pipe and out from the other side. Flow is assumed steady and I use k-epsilon model of viscosity. Here's the GAMBIT model:
The goal is to calculate the pressure drop, but I still new to FLUENT so I don't know what to do. I have already mesh it with element: quad, type: map, and interval size: 1. I give velocity inlet and pressure outlet as it's boundary condition. Here's the detail of my problem:
- inlet diameter and outlet diameter: 0.1 m
- pipe length: 1 m
- small diameter: 0.004 m
- fluid: water liquid
- inlet velocity: 0.2 m/s
- Reynolds number: 7961.715
- Turbulent Intensity: 5.2%
Other parameters like fluid property has already set in FLUENT. Is there any other data did I have to enter in FLUENT? For your info, I use FLUENT 6.3.26. Please show me steps to get data about pressure drop.
Please help me to solve my problem. I really need it. Thank you so much everybody...
Primadhani is offline   Reply With Quote
Old   May 11, 2011, 20:41
Kumar
KumarP is on a distinguished road
Hi
Everything looks ok. You just have to solve it
KumarP is offline   Reply With Quote
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Outlet BC for subsonic flow in pipe andrea panizza FLUENT 6 May 10, 2003 07:44
Flow through a pipe with constriction Murali FLUENT 5 October 8, 2002 10:55
Pipe flow John Grimm Main CFD Forum 8 March 11, 2002 12:15
