Import IGS file into gambit
Old   May 12, 2000, 00:10
Default Import IGS file into gambit
Burley
hi,
I imported a 3D graphic igs file (transformed from the DXF file), but it is fully filled with vertexes and numerous tiny element made of tiny edges.
I found it is totally diffifult to generate the surface for the figure and further mesh on that. could anyone can provide any suggestions?
Thx a lot
Burley
Old   May 27, 2000, 15:00
Default Re: Import IGS file into gambit
Daniel Malone
Burley,
I operate a business that specializes in CAD neutral file healing, repair and simplification. We can edit any iges file to collapse small details. Our website is http://www.cadrepair.com and you can email for more information at info@cadrepair.com.
Dan
Old   July 11, 2000, 17:41
Oliver
Hi
Don't even bother with an iges import, it almost a complete waste of time. If the geometry is 2D, create a 2D Solid [Autocad R12, ....R2000, MDesktop or even via solid works] if 3D, create a 3D solid. Export the geometry via the Sat translator. The geometry once imported into Gambit is real [i.e. 2D Face or 3D solid. So Unstructured or Hybrid meshing is really easy.
Even for the most complicated geometry it a cinch
Hope this helps.
Oliver
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
hwo to import a *.neu file to gambit? edongliang FLUENT 4 October 8, 2008 21:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
