energy balance fipost
Old   May 19, 2000, 10:25
Default energy balance fipost
Ralf Kroeger
i have problems in calculating an integral energy balance of a simple 2D problem solved with fidap. simplified description:
---------------------------------------------------- edge1
|||||||||||||||||||||||||||||||||||||||||| solid ||||||||||||||||||||||||||||||||||||||||||||||||||
---------------------------------------------------- edge2
in ~ ~ ~ ~ ~ ~ ~ ~ ~ fluid ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ out
---------------------------------------------------- edge3
---------------------------------------------------- edge4
fluid flows from left to right through plane 2D duct surrounded by solids
edge1: BCFLUX (heat,const)
edge4: adiabatic
turbulent, standard k-eps
the solution has converged to velc=1e-4
y+ values at edge2 are between 30 and 100 for momentum and energy
problem in fipost:
- the summation of the calculated temperature fluxes across "edge1" and "in" and "out" do not sum up to zero ?
- the flux(temperature) from edge2 into solid and fluid are not equal ?
does anyone know an explanation or did run into similar problems?
volumetric reaction and energy balance? m.beh FLUENT 1 October 17, 2011 17:21
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
energy balance zdz198728 Main CFD Forum 1 November 19, 2009 00:07
Energy Balance Harshad CFX 0 March 5, 2008 06:36
HELP needed: Energy balance in gaseous combustion James Willie FLUENT 11 August 10, 2005 04:58
