udf compilation
Old   August 10, 2000, 10:39
Default udf compilation
jy
Hello, I am contacting you for help concerning the makefile under windows NT for the Fluent5 compiled UDF with additional object files. I tried the following modification of the object line in 'makefile':
OBJECTS = $(UDF_OBJECT) $(SRC_OBJECT) additional.obj
which is simply the same modif as on UNIX where it is working: we add the list of additional object files.
The error message I get when running nmake is 'cannot find dfor.lib' and is related to the linking.
Under Unix we had to use the correct flags (-lm) when compiling and linking to allow access to external mathematical functions such as exp(), cos(), min, max...
It seems to me that we miss just a little modification on the linking part (path, or options) to make it work under NT with cl compiler. I would like to require your help on this matter.
Regards,
jy
UDF compilation problem on Linux System Nitin Pathak Fluent UDF and Scheme Programming 6 September 29, 2018 21:26
UDF compilation error Szabolcs Varga Fluent UDF and Scheme Programming 4 September 14, 2015 06:27
UDF compilation problem -- "undeclared variable" Henrik Ström FLUENT 1 September 21, 2005 06:25
UDF compilation error Szabolcs Varga FLUENT 2 April 14, 2004 11:12
Compiled UDF / Compilation problem mikhail FLUENT 1 October 13, 2000 07:12
