FLUENT 2D
Old   September 14, 2000, 02:50
Default FLUENT 2D
PAI
I am modelling a plane slider bearing in 2d using GAMBIT. The solution is done using FLUENT 5 solver.
The problem I encounter is -
The pressure profile on the stationary wall gives me a negative value at the inlet, while actually it sholud be positive. Rest of the profile builds to a positive value after the initial dip.
I know that FLUENT solves the Bernoulli equation at the inlet. But that's the problem here.
I have tried using a finer grid/grid adaptation etc. but the results are the same.
Is there a way of getting over this problem?
PAI
Old   September 16, 2000, 00:26
Default Re: FLUENT 2D
John C. Chien
(1). If the solution is mesh independent, and the pressure is negative, then you should try some other codes, because negative pressure has no meaning at all. (2). By the way, before you try other codes, make sure that you are reading the right pressure. I mean, these codes don't solve the real pressure in the solution algorithm sometimes.
Old   September 16, 2000, 09:42
Maurizio Barbato
Dear John,
the negative pressure should be the value of the so called gauge pressure, i.e. the value obtained substracting the mean pressure (assigned as problem parameter) to the real pressure value. Therefore a negative gauge pressure means a pressure under the mean value assigned.
Cheers
Maurizio
Old   September 17, 2000, 02:19
John C. Chien
(1). I hope you are right, otherwise, there is a long way from the negative pressure to the positive pressure.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
