Near wall particles
Old   September 1, 2000, 03:24
Default Near wall particles
Staffan
I'm simulating particle flow in a combustion chamber. My particles are of the sizes: 0.0001m, 1e-5m and 1e-6m. The problem is that small particles hits the walls as often as the bigger ones. In reality the small ones should follow the gasflow. How does fluent calculate near wall threatment of particles? a.) Is a particle considerd as trapped (escaped or reflexed) when it enters the cell next to the wall or when the particle actually hits the wall? b.)Does the mesh size near the boundaries influence the results of the near wall threatment of particles?
Thanks, Staffan
Old   September 4, 2000, 12:38
Default Re: Near wall particles
Rüdiger Schwarze
I've got the same unphysical results in a similar problem. I think that the drw model is responsible for these errors. The particle obtains a fluctuating velocity u' in the free flow field and an eddy life time which is much more longer the the flying time through the boundary layer.
Old   October 2, 2000, 08:47
Hesham El-Batsh
I think the turbulence model has great effect. For example, the standard k-e model is a fully turbulent model and generates high turbulent knietic energy which affects the particle fluctuating velocity used in RWM and finally increases the number of particles hitting the surface. To accurately predict particle dispersion near the wall using RWM, low Reynolds number models are required. The other possibility is to use damping functions in the near wall region. One of the damping functions can be found in this reference: Wang, Y. and James, P. W. "On the Effect of Anisotropy on the Turbulent Dispersion and Deposition of Small Particles" International Journal of Multiphase flow, v. 25, pp. 551-558, 1999
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 04:08
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
