October 5, 2000, 08:09 |
Importing from CAD package
As anyone had any experience importing a CAD file into Fluent 4.5 and above ? We all know about that geometric input is the longest part so I'm attempting this at some stage.
October 5, 2000, 09:02 |
Re: Importing from CAD package
If you use AutoCAD, it works just perfect with the AcIS export/Import, because they use the same APIs...
October 5, 2000, 10:51 |
Thanks for the tip. Getting AutoCAD is fine. Which version of Fluent have you used this in ? I'm using 4.5. But 5.3 and 5.4 is avialable.
October 5, 2000, 10:53 |
I am using 5.3, for AutoCAD you need to export as AcIs file (.sta extension, if I remember right).
It is always better to simplify the geometry in CAD first... |
October 5, 2000, 11:03 |
Hi Kai,
The file extension for ACIS files is .sat I had alot of problems with geometry. Exporting from Solidworks. Have you any ideas as to how this can be effectively done? Thanks. |
October 6, 2000, 07:08 |
That file has to be imported into Gambit and not into Fluent itself.
October 6, 2000, 09:36 |
you are right, should be Gambit instead of Fluent
October 6, 2000, 15:13 |
Hi
Depending on the CAD software you are using, you can export the geometry as a variety of Standards Pro Engineer STEP Solidworks STEP/SAT AUTOCAD, MDESKTOP SAT If you have any problems, with the above formats, try and save them as a lower version, because there could be a inconstency between GAMBITS Translator and the version of the translator used in the CAD package Regards Oliver |
October 25, 2000, 10:52 |
#9 |
Jack,
I operate a business, CAD Repair, that specializes in translating, healing and repairing CAD neutral files. I may be able to help you. Dan Malone dpm@cadrepair.com 412-820-9205 |
Importing CAD geometry and Editing edges to match | Ahmed | CFX | 15 | March 21, 2016 12:39 |
Extend Project 1.6-ext Binary Release for Mac OS X | hjasak | OpenFOAM Announcements from Other Sources | 26 | November 5, 2013 16:50 |
Recording Journa file: Importing CAD Geometry | franzahir | FLUENT | 0 | June 25, 2009 10:50 |
ploblem with importing CAD file into Star-Design | caoll | Siemens | 0 | March 17, 2008 20:00 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
