November 3, 2000, 10:04 |
Boundary conditions for two phase flow
Hi every one, I am a new user of Fluent and need help! My goal is to simulate multiphase flow in which the interfacial area is in my first interest. The two fluids must introduce to the domain from one inlet and leave the domain from one outlet. Or they would be introduced to the domain in countercurrent modus. The gravity and the surface tension must be included in the solution. My quistion: What kind of boundary conditons should I difine for the outlets if I have a velocity inlets for the two fluids?
Every answer is appriciated best regards Adel Ataki |
November 6, 2000, 17:35 |
Re: Boundary conditions for two phase flow
I think maybe outlet flow is OK.
November 9, 2000, 04:24 |
Hallo ronny, at first thank you for your answer. If I choose an outflow for every phase, I should give a value for the Flow Rate Weighting! will this Flow Rate Weighting be calculated for every phase or it includes the total flow of two fluids? best regards Adel Ataki
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
boundary conditions for 2D flow around a circle | abcdef123 | Main CFD Forum | 0 | April 21, 2010 02:26 |
Outlet boundary conditions for unsteady flow | Bjorn B | Main CFD Forum | 3 | January 11, 2006 05:42 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
