Velocity inlet
Old   November 17, 2000, 01:52
Default Velocity inlet
Max
i'm doing the simulation on 2 phase(water & air)flow in a horizontal pipe.which phase should i set as primary phase?why? during the setting of boundary condition, the velocity magnitude in velocity inlet is referred to the primary phase velocity or the secondary phase velocity?could anyone please help me to solve my doubt?thank you!
Old   November 17, 2000, 16:30
Default Re: Velocity inlet
kevin
According to the manual, the phase that has the lowest volume fraction must be the second phase.
Old   November 18, 2000, 10:24
Max
kevin, then,during the setting of boundary condition, the velocity magnitude in velocity inlet is referred to the primary phase velocity or the secondary phase velocity?
Max
Old   November 20, 2000, 11:45
Adel Ataki
Hallo Max, thank you for your help. I think the problem is how to choose the inlet and the outlet boundaries! for the velocity-inlet, pressure-inlet, pressure-outlet you ought to give the Volume-Fractions for the secondary phase! for an outflow you you need to give a Flow Weighting Rate! The quistion is how does VOF model work? Best regards Adel
Old   November 22, 2000, 10:36
kevin
Yes Max
Old   November 22, 2000, 11:10
Max
kevin, Yes?what is your answer referred to?
Max
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 05:45
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 09:02
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
