November 29, 2000, 03:48 |
Problems with residuals??
Hi CFD-users,
I'm a FLUENT 5.4.- user and I try to simulate the flow inside a stirred tank. For the motion of the stirrer I use the MRF-Model. The viscous model is the standard k-epsilon. I begin my calculations with very low rotational speed and after reaching a destined convergence, I increase the speed. When I postulate small scale residuals it's no problem for the x-velocity, y-velocity, z-velocity, k and epsilon to get a small value. At 10^-7 they all reach a kind of "steady state" where no changes could be recognized; but the continuity reach a stedy state at 10^-6. When I now increase the rotational speed step by step, all residulas will find "this steady state" at the value 10^-7 again except for the continuity. The residual for the continuity is increasing while I increase the speed. To my questions: 1)Is this normal that the residual for the continuity is increasing while I increase the speed? 2)What adjustments do I have to change to solve this problem? Solve Control Solution: Under-relaxation factors Pressure 0.3 Momentum 0.7 Turbulence Kinetic Energy 0.8 Turbulence Dissipation Rate 0.8 Viscosity 1.0 Density 1.0 Body Forces 1.0 Discretization Pressure PRESTO! Momentum First Order Upwind Pressure-Velocity Coupling SIMPLE Turbulence Kinetic Energy First Order Upwind Turbulence Dissipation Rate First Order Upwind Thanks Peter |
Display Modes | |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Problems with residuals oscillations | spacecraft | STAR-CCM+ | 2 | September 13, 2010 08:57 |
problems with residuals in fluent. | Tan | FLUENT | 3 | February 10, 2009 10:05 |
Problems with residuals | Martin | CFX | 2 | January 2, 2007 22:10 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
