December 2, 2000, 23:06 |
turbulence kinetic energy?
What is the formula to define the turbulence kinetic energy and turbulence dissipation rate? I am using the k-epsilon and VOF model? Thanks for any suggestion.
December 3, 2000, 10:41 |
Re: turbulence kinetic energy?
a good guess is: k = 1.5 * (U * TI)^2 [m^2/s^2] eps = Cmu^0.75 * (k^1.5 / (0.07 * L)) [m^2/s^3] where U is the average (reference) velocity [m/s] TI is the turbulent intensity which depends on the case (e.g. = 0.10 means turbulence that velocity turbulent fluctuations have an aplitude which is 10% of the average velocity) Cmu = 0.09 is a constant L is a characteristic dimension which depends on the case (e.g. tube diameter) [m] I hope this helps. Cheers Maurizio |
fluctuations in turbulence frequency and kinetic energy | rskrishna87 | CFX | 2 | June 11, 2011 15:45 |
【Discrete Phase Method】about the turbulence kinetic energy | charlesluan | FLUENT | 0 | April 22, 2010 07:21 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Turbulence kinetic energy formula | ranjit | FLUENT | 1 | January 25, 2007 14:36 |
Turbulence kinetic energy transfer | Jun | FLUENT | 0 | April 11, 2006 23:52 |
