Laminar flow
Old   January 19, 2001, 13:32
Default Laminar flow
Francisco Saldarriaga
Fluid comunity: A question: As rule of thumb and without making any calculation, What is the length required to establish a laminar flow (of gas = air ) through a 2" DIA tube downstream of the elbow, if it were 90 degrees?
Old   January 19, 2001, 14:42
Default Re: Laminar flow
John C. Chien
(1). The flow will be turbulent all the way downstream of the elbow, if I understand your "laminar flow" definition correctly.
Old   January 21, 2001, 10:40
olivia
Hi: I thank if Re number is small ,It is possible that fluid flow a bend that still have laminer . But I thanks it will happens secondary flow.
Old   January 21, 2001, 13:49
John C. Chien
(1). Well I guess, if he turns off the vlave, then, there will be no flow in the pipe. The flow will become laminar if one wait long enough. (2). The critical Reynolds number for flow to become turbulent in a smooth pipe is Re,cre=2300. For a 2"DIA pipe, and air flow, the mean flow velocity will have to be less than a couple of feet per second, which is about 1.5mile/hour wind. (3). I think, one can always make the flow laminar, if the flow rate is reduced such that the mean velocity in the pipe is below 2ft/sec.
Old   January 22, 2001, 06:27
John and olivia: Thanks to both! Point well taken, there are secondary flows and it is difficult to keep it laminar due to the velocities involved!
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 10:42
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 10:35
grid for laminar flow kim FLUENT 2 April 4, 2002 02:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
