Rake Creation Problem
Old   January 24, 2001, 15:45
Default Rake Creation Problem
Prateep Chatterjee
I've graduated from Fluent 5.3 to ver 5.5. Still encounter problems with generating rakes/lines. I'm trying to generate a rake of, say x_min = -0.019 m & x_max = 0.019 m (z fixed), but when I plot data with the xy plot option (and also export data to files), I observe that x_min & x_max change to ~ -0.014 m and 0.014 m respectively.
I'm unable get the exact dimensions to appear even if I increase the x_min & x_max values to say -0.025 m & 0.025 m resp. - the final result remains the same. I'm pretty sure that the dimension that I choose are correct (I can see the line/rake along with the geometry and their positions and dimensions look fine).
Any suggestions anybody ?
Old   February 2, 2001, 04:14
Default Re: Rake Creation Problem
Volker Pawlik
the dimensions for the rake/line always take the limit of the domain. The ccordinates you supply only define the direction. Hence to limit the rake to you have to use the clip-surfcae function.
Volker
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
A CAD creation problem hamid1 FLUENT 4 February 18, 2011 13:24
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
ANSYS ICEM CFD: lsdyna input file creation problem Evan CFX 0 June 15, 2006 14:12
