Multiphase capabilities
Old   February 26, 2001, 10:50
Default Multiphase capabilities
amc
Can anyone tell me the multiphase capabilities of fluent? Is three phase, (a non-newtonian liquid, a gas and solid particles) pipe flow modelling possible? I believe that until Fluent 6 is released, Fluent 4.5 has to be used for this type of multiphase modelling. Is this the case? Is it possible to model the different flow patterns associated with gas-liquid pipe flow (i.e. stratified, slug, annular, bubble etc.)? Any answers would be appreciated.
Old   March 1, 2001, 23:11
Default Re: Multiphase capabilities
Newbie also
In principle the Eulerian model of fluent is k-fluid so it must be able to handle 3 phases or more, and yes, this model is only available in fluent 4.5 and will be available in fluent 6 in june 2001 ( according to the fluent engineers).
Depending on the flow you're interested, the model of choice must be different, for example if you are modeling stratified, slug or annular flow I would suggest to explore the VOF model (available in fluent 5), but if you are modeling bubble flow it's almost sure that you must use a Lagrangian approach. For the solid particles-liquid-gas I'm not sure, it must depend on the concentration of solids (granular model?) and volume fraction of the gas, and if it can be considered as a diluted liquid or not, but I'm sure there must be somebody else that can give you a better answer that I would like to hear. As you see there's no simple answer to your question.
Hope this helps
Sincerely Arturo
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
About the multiphase flow Xue FLUENT 4 September 19, 2008 13:05
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
