Non-premixed combustion: local heat release rate
Old   September 3, 2007, 12:58
Default Non-premixed combustion: local heat release rate
LB
Hi I was was wondering how the local heat release rate is calculated in Fluent??? I know in FDS it is computed by "first locating the flame sheet, then computing the local heat release rate per unit area, and finally distributing this to the grid cells that cut the flame sheet, so the infintesimally thin flame sheet is smeared out over the width of the cell"
Is Fluent the same?
Thanks in advance for your help!
Old   April 28, 2021, 22:11
Default simulating combustion noise by hybrid method
jimmy_chan's Avatar
chenjingzhen
jimmy_chan is on a distinguished road
Hi, have you solved the problem? can you please tell me how do you calculate the heat release rate(or define the custom field function) in fluent?
I deeply need the data on the heat release rate!!
sincerely thank you
Love is the best gift to others
jimmy_chan is offline   Reply With Quote
heat release rate calculation Karthick .K FLUENT 2 April 28, 2021 22:15
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 10:40
rate exponent for combustion modeling.. palani kumar FLUENT 5 May 17, 2016 03:27
heat release rate in output file Caty CFX 6 June 16, 2014 11:06
Help on premixed combustion heat seaspace Main CFD Forum 2 May 27, 2003 05:28
