March 7, 2001, 22:55 |
GAMBIT merge and export mesh
In gambit,select solver as Fluent5. file name: test.
After split a volume into two parts, mesh each of them seperatively, then merge them(real), export mesh, the trn file says: to GAMBIT Neutral file\tfilter fe2ram -surface -tGAMBIT >test.msh However, as I read the mesh into FLUENT5.48(read-case), it says Error: FLUENT received fatal signal (ACCESS_VIOLATION) I once exported the mesh before merging the two volumes,and FLUENT worked well. Guys, help! |
March 8, 2001, 07:11 |
Re: GAMBIT merge and export mesh
Before merging the 2 meshed volumes, have a look at the mesh : use the Examine Mesh panel (right-hand side, at the bottom of your screen). In the "Range" menu, you can see that there is a certain number of 3D cells. You can also display a cut to see the cells.
Now if you merge the 2 volumes, examining the mesh will tell you that there is no 3D cell any more. Only faces. That is why Fluent does not appreciate to read a 3D mesh, which is only a skin mesh (2D cells). |
March 8, 2001, 07:18 |
Then what shall I do?
March 8, 2001, 07:33 |
Start meshing only when your geometry modifications are done.
March 8, 2001, 07:50 |
Flav, What shall I modify the geometry?
question on generating sliding mesh in Gambit | multiphase-flow | FLUENT | 4 | February 21, 2012 00:36 |
Mesh 2 bodies in 2 different programs | Doginal | ANSYS Meshing & Geometry | 4 | September 21, 2011 12:16 |
Export 2D mesh from ICEM to Fluent | BuilttoSpill | ANSYS Meshing & Geometry | 4 | August 28, 2010 08:16 |
importing Icem mesh into Gambit | srinivas | FLUENT | 4 | December 12, 2008 04:06 |
Gambit error in exporting mesh in 3D modeling | Mazyar | FLUENT | 5 | March 31, 2004 10:50 |
