DEFINE_DPM_LAW
Like Tree1Likes
  • 1 Post By Rüdiger Schwarze
Old   March 14, 2001, 01:13
Default DEFINE_DPM_LAW
Ramesh K
In my problem, solid particles are injected into the 3D jet and would like to incorporate latent heat of melting to the particles. For this, it is needed to use DEFINE_DPM_LAW. But, i am facing problems in doing it. I do not understand how to communicate with source code to include the heat transfer to the particles. That is, by using which Macro in the DEFINE_DPM_LAW macro, it is possible to communicate with the source code to include "latent heat of melting".
Thanks in Advance, Ramesh.
Old   March 15, 2001, 03:45
Default Re: DEFINE_DPM_LAW
Rüdiger Schwarze
DPM_LATENT_HEAT(p) is the particle material latent heat.
qinchangliang likes this.
Old   March 16, 2001, 01:45
Ramesh K
Hi Schwarze,
Thank you for the response. My qusetion is how to include the laten heat of melting (not laten heat of vaporization) to the particle energy equation via the DEFINE_DPM_LAW. In the enegry equation for droplet, the energy equation is (m cp.dT/dt = h.A.dT + dmp/dt.Hfg). But, I want to include the additional term (mp.Hsf) where Hsf is the latent heat of metling as my injected particles are solid.
Any help will he greately appreciated,
Thank you and Regards, Remesh.
Old   March 18, 2001, 20:53
Default (Please Help!!!!): DEFINE_DPM_LAW
Ramesh K
Dear Fluent 5 users, I am in dire need to write the UDF. Please help me!!!! Any example UDF using DEFINE_DPM_LAW will be of much help. Please help!!!!!!
Regards, Remesh.
Old   March 21, 2001, 16:39
shery
Hi Ramesh: I'm not sure if I understand your problem.I think you want to add a term to your energy equation is that right? as far as I know the energy equation used in Fluent is: MpCpdTp/dt=convection +radiation to add latent heat to your equation simply include the "energy equation + the latent heat" in you source.so to look at the heat transfer to particles turn off the default method which is Inert-heating and use your own code. I hope it helps shery
