March 29, 2001, 06:51 |
Deflection observed, Why?
I'm currently trying to model the dispersion pattern of a buoyant plume rising vertically from the sea floor under the effect of currents. I noticed that the dispersion pattern at the surface is not symmetrical about the centreline, tending to deflect to one of the symmetry plane. (my comp domain is rectangular with upstream and downstream defined as vel-inlet and p-outlet resp. The sides and top surface were defined as sym boundaries. Bottom is wall.) Anybody knows what is the cause of the deflection, and any way of removing/improving the results? Does changing the grids help? Please help, Thanx! Cheers JJ |
March 30, 2001, 12:30 |
Re: Deflection observed, Why?
I've seen that problem before, and I corrected it with a finer grid at the symmetry boundary.
March 31, 2001, 02:55 |
Hi Scott,
Thanx for the reply...really appreciate it. When u mention a finer frid at the symmetry boundary, do u mean at the symmetry face itself or the region near the symmetry plane? Should be the latter rite? May I ask also, how fine was the grid u adopted? Thanx again. Cheers JJ |
help debugging Beam deflection UDF | josik_1982 | Fluent UDF and Scheme Programming | 0 | December 19, 2010 17:36 |
In what range should the observed order of grid convergence be? | jack1980 | FLUENT | 0 | March 9, 2010 09:59 |
Turbomach. Estimated and observed data discrepancy | Georg | CFX | 1 | March 13, 2009 09:47 |
ansys to investigate deflection of wing | xuefeng | Main CFD Forum | 3 | December 2, 2008 16:13 |
Source file to compute wing deflection | Jerry | Main CFD Forum | 0 | January 7, 2004 00:55 |
