April 20, 2001, 22:19 |
GAMBIT grid export problem
I am a new user of Fluent. I meshed a cylinder with 3D elements by GAMBIT and exported it. But when I imported the grids into Fluent and checked it, I found I can't find correct boundary zones, thus I don't know how to add boundary conditions. Anyone can help me? Thanks a lot.
April 22, 2001, 02:46 |
Re: GAMBIT grid export problem
You should define your boundary zones in Gambit (first define the solver (Fluent 5 I presume). Then you can define actual boundary conditions in Fluent.
Yulia. |
April 23, 2001, 04:08 |
Hi, In gambit after defining the solver as Fluent 5 and meshing the computed domain, you should define your boundary zones with "zone command button" . Then you can export mesh file and read into fluent 5 and then define actual boundary conditions in Fluent. I hope it can give you a hand. Harry.
Gambit Axisymmetric Neutral File Problem | SandyS | OpenFOAM | 4 | March 25, 2014 07:08 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 02:19 |
Problem importing solidworks to gambit | holyo | ANSYS Meshing & Geometry | 3 | April 16, 2010 05:16 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 10:26 |
