April 20, 2001, 23:46 |
how read Gambit data into my solver
How could I read a multiblock,structured grid generated by Gambit into my own solver? Any suggestions would be highly appreciated! Thanks for your attentions! |
April 22, 2001, 02:44 |
Re: how read Gambit data into my solver
You can create the grid without defining specific solver ("Sover Generic") and then save the Generic Neutral file by following sequence: File -> Export -> Mesh. This is an ascii file describing your mesh (please refer to Appendix (i think it is part B) in Gambit user guid which describes the folmat of the neutral file in details. Then you should be able to read the mesh into your own solver "point by point". Hope this helps. Yulia. |
April 22, 2001, 05:41 |
hi, After u have saved ur mesh file. click the option ,export --> mesh in the file menu. It gives a dialog box to save the mesh as file.msh. Click yes. Read the .msh file in fluent. FILE--READ--mesh file. after it has read the meash file , save it , by write option. file--write--case file(case file is created by this time) I think this would clear ur doubt.. good luck......... Chubby
April 23, 2001, 20:18 |
Yes, using the neutral file is easiest and the format is pretty simple - just a list of nodes and node connectivity and some b/c defs.
I have used this method to use Gambit as a grid generator for a finite element structural analysis program - which didn't have parametric design capability. Greg |
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) | hadikhayyamian | ANSYS Meshing & Geometry | 5 | December 21, 2010 12:28 |
FLUENT can not read data file | jing113cn | FLUENT | 0 | December 6, 2010 09:06 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
Is it possible to read case file in gambit | sivaraja | FLUENT | 1 | May 8, 2009 08:58 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
