April 11, 2001, 22:46 |
Two-fluid model
Dear all,
Who has experience using two-fluid model to simulate gas-solid two-phase flows? In Fluent5.4, I only find three multiphase models in the User's Guide: VOF, Cavitation model, and ASM model. It is said at www.fluent.com that the kinetic theroy of particulate phase (or said Eulerian-Granular model)has beed adopted in Fluent. How to find and use it in Fluent? Thanks. |
April 12, 2001, 03:14 |
Re: Two-fluid model
Try Fluent 4.5 it has the granular model inbuilt.
April 12, 2001, 04:56 |
Re: Two-fluid model
I tried Fluent 4.5 but I was disappointed.
Ray |
April 13, 2001, 15:59 |
Re: Two-fluid model
I am not sure what you are solving. Are you simulating gas-solid problem? If so, it does not look like a two-phase flow problem to me. If you just want to solve energy equation in your solid zone (heat conduction), then it is a conjugate problem. Fluent can handle that pretty easily.
If I didn't understand your problem correctly, please correct me. I was just trying to help. |
April 24, 2001, 02:08 |
Re: Two-fluid model
Then finally, how do you find the solution? Because I am also plan to use fluent4 to simulate gas-solids two-phase flow. Is there any other way to get the results of gas-solids flow? Both in dilute or dense flow?
RGDS, Daninwin |
MRF MODEL :Stationary blades and fluid rotaion Dir | FERRARI | FLUENT | 0 | November 5, 2008 01:25 |
Different fluid model in single analysis | rajinikanth | FLUENT | 0 | February 12, 2007 06:48 |
Mixture model with one compressible fluid phase | oden | FLUENT | 0 | September 26, 2006 09:11 |
Using UDF to model bubble growing in a Fluid | Daniel Ofori | FLUENT | 0 | September 6, 2006 16:44 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
