April 24, 2001, 11:26 |
dxf in gambit
I want to import a dxf-file in gambit. How can i do this?
April 26, 2001, 12:22 |
Re: dxf in gambit
I must convert your dxf file into a Gambit readable format such as IGES or ACIS. There is only a few cad programs which are able to do this job as dxf is often diffficult to read. You could try AMAPI3D which is a very 3D modeler with a wide number of import and export format. Best regards Alain |
April 26, 2001, 15:05 |
Re: dxf in gambit
Use Rhinoceros 3D to convert your DXF file to STL. Gambit supports STL import.
Display Modes | |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
between IDL Gambit and rhino, any help? | philip | FLUENT | 0 | June 23, 2005 12:08 |
dxf files and gambit or fluent | Lio | FLUENT | 6 | June 23, 2004 10:41 |
