Postprocesing Fluent
Old   April 9, 2001, 22:56
Default Postprocesing Fluent
Newbie
Hi y'all
I find the postprocessing tool of fluent very limited to produce the kind of graphs I need, mainly slice graphs vertical and horizontal. Also I need to modify the ranges and some other fine tuning and with fluent I find it painful and lengthly compared with other programs I've used before but unfortunately not compatible with fluent.
I think it would be useful to all ( mainly newbies as me) to hear from experiences in the postprocessing tools you use to produce publication-quality graphics.
Thanks
Old   April 10, 2001, 09:27
Default Re: Postprocesing Fluent
Sandeep
Write out the fluent results to a data file and then use Sigma Plot to produce those publication quality graphs..
Old   April 10, 2001, 12:20
Scott W
Create an iso-surface of constant grid position. That will give you slice graphs vertically and horizontally. It sounds like you are working in 3D. Turn on a light (under display-options), Gouraud is quick and makes your display much more professional looking. Of course, when you look at 2D slices, turn those lights off.
I'd love Fluent to expand the ranges tool. For example, currently you can auto-calculate both ends of the range or manually input both ends. Why not have the ability to manually input one end and calculate the other?
The biggest problem I have, is the great 22 inch pictures made by Fluent or other graphics programs are terrible when printed on paper. Anyone have good ideas for this?
Old   April 11, 2001, 19:16
Newbie
Thanks Scott, I've tryied your method and it works well. Anyway I can't stop comparing fluent with the possibilities of other postprocessing softwares that, by the way, doesn't accept the "universal" fluent files and have a much easier interface and dedicated features.
Sandeep, does Sigmaplot accept formated files from fluent or you do have to postprocess them?, can you be more explicit?.
Newbie
Old   April 12, 2001, 13:31
Sandeep
Sigmaplot does not accept formatted files from fluent. You have to post process them. But the quality of graphs generated after that is spectacular. I havent come across a better software than sigmaplot for graph generation.
Old   April 12, 2001, 13:35
Sandeep
Would like to make a correction to my previous post. If your data file in "comma delimited" type format...sigmaplot can read it in !.
Old   April 24, 2001, 05:17
Default To Scott Whitney
Sundar
Hi Scott Whitney, How r u. This is Sundar. I hope you still remember me. I am the same one who came to Univ of lincoln to learn fluent from you. My email id is ja_sundar@hotmail.com. I would like to hear from you. keep in touch. sundar.
Old   April 25, 2001, 17:47
MIckael
Tecplot is really suitable for this kind of things. I am doing all my post-processing using this software. It is really powerfull and flexible.
You can also very easily import you data from Fluent (.cas and .dat), as a Tecplot loader is now available.
Only one bad point for this software : its price !
You can have some more details on the following website : www.amtec.com
I hope it wiil help you !
Regards
Mickael
Old   June 4, 2001, 06:49
hb_science
when I import the .dat and .cas to the tecplot9 I can't find variable"M " that I needed, there are only some variable such as "x-velocity" "y-velocity","T" etc. How can I get the variables information I wanted in the TECPLOT 9? in other words ,can I control the variables that would export from fluent? thanks!
Old   June 4, 2001, 11:56
Mickaël
Hello !
I never had this kind of problems I am using Tecplot 8. But you can easily bypass your problem : you can easily calculate
1) The local sound speed
2) The velocity magnitude
3) The Mach number (ratio of the 2 previous)
I hope it will help U !
Regards,
Mickaël
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
