June 12, 2001, 02:32 |
uniform distribution of velocity
I AM TRYING TO MODEL INCOMPRESSIBLE FLOW IN A MICROCHANNEL.. THE MICROCHANNEL HAS A SECTION LIKE A TRUNCATED CONE TILL A DISTANCE 1.5MM AND THEN AN UNIFORM CHANNEL FLOW AFTER THAT UPTO 32MM. DOES ANYONE KNOW HOW TO GET A UNIFORM PROFILE OF VELOCITY AT THE CHANNEL AFTER SOME DISTANCE DOWNSTREAM GIVEN THE GEOMETRY. I AM OPEN TO SUGGESTIONS REGARDING THE USE OF OBSTRUCTIONS IN THE FLUID PATH... THANKS
Velocity fluctuation distribution near a wall | Matthieu | FLUENT | 1 | June 3, 2021 09:40 |
Channel flow: Inlet pressure AND uniform velocity? | frmap1 | Main CFD Forum | 0 | April 15, 2010 10:32 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 03:01 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
non uniform velocity profile at inlet | hiba | FLUENT | 2 | July 25, 2006 03:32 |
