Wall Heat Tramsfer Coefficient - UDF
Old   June 25, 2001, 00:31
Default Wall Heat Tramsfer Coefficient - UDF
Greg Perkins
Hi all,
I want to access Fluent's calculated heat transfer co-efficient at a wall. According to p85 of my (old) udf manual this can be accessed via:
h = RP_Get_Real("udf/heat-transfer-coefficient");
but I get an error from Fluent when using this function - apparently it doesn't now about this variable.
Also, I would have thought that the heat transfer co-efficient is a local value - and thus not a global RP variable at all. So what does this do from example 5.6 in the udf manual??
I have found that the past variabled cid[1], cid[2] are non-zero and look like they may have the values of the heat transfer co-efficient as computed by Fluent. Can anybody confirm this??
Greg
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
heat flow UDF on coupled surface (wall-shadow wall) Friedmann Fluent UDF and Scheme Programming 0 August 5, 2010 10:25
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
