modelling Dessicant Wheel for HVAC??
Old   July 1, 2001, 01:40
Default modelling Dessicant Wheel for HVAC??
Harry Qiu
Dear Mr or Ms:
Can I use FLUENT to modeling Dessicant Wheel in the HVAC field? If it can, how to simulating mass transfer(vapor) between the solid and air? Thank you very much. Any suggestion are welcomed!
Sincerely yours, Harry.
Meshing a Wheel in Pointwise/Fluent problem Marli Pointwise & Gridgen 6 March 27, 2020 00:47
Rotating Wheel Example/Information Required scott OpenFOAM 1 March 11, 2012 13:49
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Output Pressure reults for rotating wheel. HELP Krishan Parmar Phoenics 0 July 2, 2007 14:11
how to ensure that your modelling is correct rvndr Main CFD Forum 7 March 1, 2004 12:21
