July 20, 2001, 10:46 |
grid check failure
What are the common causes of grid check failure in Fluent?
The grid statistics that I see when I am reading in my mesh tell me that I have some left-handed cells. The users guide tells me that left handed cells are a connectivity problem and that usually these are associated with a negative minimum cell volume. The statistics for my mesh don't indicate a negative cell volume. So I don't know if I truly have a connectivity problem, or what is causing my connectivity problem. Also, the users guide suggests that you can find the problem cells using the Iso-value adaption option, but since I don't have any negative volumes nothing is marked when I attempt to use Iso-value adaption. Any ideas?? It is a fully structured 3d mesh. |
July 25, 2001, 08:15 |
Re: grid check failure
1) Check the duplicacy of vertices and edges. 2) Check the tolerances in Gambit. 2) Check the element Skewness.
AJ |
July 30, 2001, 09:05 |
I suggest remove the mesh, then connect faces, edges and vertices, then mesh again. After each volume mesh do a mesh check ( if there is a no good meshing you receive a message ). If not enough, split the volume and try everything again.
August 1, 2001, 15:17 |
I had the same problem and asked the same questions. The only way I fixed the problem was smoothing the mesh, maybe you will have to do it several times and it would be better to make a new mesh.
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
Grid Check Fails in Parallel Processing Mode | askance | Main CFD Forum | 0 | October 20, 2010 10:11 |
grid check failed | yubaibai88 | FLUENT | 5 | April 7, 2010 07:05 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
help! grid check error | Gary Holland | FLUENT | 9 | April 25, 2005 13:37 |
