source of energy
Old   July 10, 2001, 13:40
Default source of energy
Benoit
Hi! I try the UDF for sources of energy, but it doesn't work! : acces violation at the beginning of the solve. For other sources (species for example) I've no problems.
So I need your advices!
Old   July 12, 2001, 05:05
Default Re: source of energy
Greg Perkins
Could be many things. Check that the variables you access such as udms have been allocated.
Its probably a simple mistake in the code somewhere - that's what mine normally are! But yeah it takes ages to find some bugs...
Greg
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
