July 16, 2001, 15:20 |
error in Gambit
Hi, everyone
I have been trying to mesh a rocket in GAMBIT. I created a flow domain by subtracting the rocket from the brick. All the faces from the rocket mesh with no problems using tri pave, but when I try to mesh the volume (using tetrahedral - Tgrid) I get the following error message: Error: Initialization failed TG_Mesh_Domain failed with error code 1 Tetrahedral meshing has failed for volume volume 6 This is usually caused by problems in the face meshes. Check the skewness of your face meshes and make sure the face mesh size is not too large in areas of small gaps. There is approx. 1 % of elements with equiangle skew of greater than 0.9. I have tried adjusting face mesh size with no luck. I am not sure how to reduce the skew value. Appreciate any help, Thanks |
July 17, 2001, 06:43 |
Re: error in Gambit
Try to check where your skewed elements are. If you can't do this with gambit use TGrid.
You may have very small or degenerate faces. Hope this could help. best regards Alain |
July 17, 2001, 10:53 |
Re: error in Gambit
You also might want to simplify (or consolidate the small features)the geometry by merging the faces in Gambit (or upstream of Gambit).
If you go the TGrid route, make sure you set the variable EXPORT_SURFACE_MESH_ONLY (Edit->Defaults; FILE_IO tab; FLUENT5 radio button) switch to 1 to allow export of the surface mesh. Tip: make sure you define all surface boundaries, ie., outer-wall, rocket-wall, pressure-inlet, etc. |
July 17, 2001, 11:03 |
Re: error in Gambit
I get this message right before volume initialization fails:
No cell intersected by bf30100(meshing bn15038) anyone know what this means? thanks for the help |
July 18, 2001, 10:29 |
Re: error in Gambit
You need to clean-up your geometry by removing small faces (small relative to the interval sizing you are using for your meshing)
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Does Gambit has a maximum allowable grid number? | spartan1516 | ANSYS Meshing & Geometry | 7 | March 25, 2010 09:08 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Problem starting Gambit | ViHAR MALViYA | FLUENT | 0 | November 10, 2006 10:26 |
