Convergence problems for a Scramjet application
Old   August 29, 2001, 02:29
Default Convergence problems for a Scramjet application
Jeff McGuire
The problem which I am trying to simulate is for a Scramjet in a Mach 6.6 freestream flow. The highest Mach number for which the solution will converge is about 3, but anything above this causes error messages to appear. Changing the solver to 'coupled explicit' no longer produces any error messages, but the solution still will not converge to the required limits. I'm not sure if there is an obvious solution to this problem as I've only been using Fluent for a few weeks, but I'd appreciate any suggestions. Thanks.
Old   August 30, 2001, 00:48
Default Re: Convergence problems for a Scramjet applicatio
david
A) U have to follow up whether there is any shock in the domain while getting any solution B) Adapt the grid where you have sudden variation of solutions parameters C) Try to find out where is the maximum residuals.
DC
Old   September 2, 2001, 01:58
John C. Chien
(1). It is a difficult problem to solve at high Mach number, and even the recent flight test of the SCRAMJET vehicle was not successful.(not due to the SCRAMJET itself but due to the more conventional rocket launch vehicle, as the report said) (2). I think, the initial flow field is very important to get any code started, and after that, you will have to chase after the wave propagation throughout the flow field. (3). These flow features are always sensitive to the mesh size and distribution.
convergence analysis for viscous problems shyamdsundar Main CFD Forum 1 September 25, 2009 13:54
Problems with convergence with an easy system franzdrs Main CFD Forum 0 June 15, 2009 18:17
Weak rotational flow - Convergence Problems Daggemann FLUENT 1 May 8, 2009 09:45
NACA0012 Convergence Problems StudentAndrew CFX 6 November 21, 2005 06:49
Convergence problems Simone Siemens 5 June 29, 2005 10:48
