WARNING:multiple shadows
Old   September 12, 2001, 01:35
Default WARNING:multiple shadows
Suneesh
hi,
I am trying to simulate the flow past rotor/stator configuration in compressor.When I import the mesh file into fluent it gives a warning that some face threads has multiple shadows.
can someone tell what may be the possible reason for this warning and also the remedy for it.
thanks and regards, suneesh
Old   September 12, 2001, 10:26
Default Re: WARNING:multiple shadows
Volker Pawlik
as far as I remember the warning can be forgotten.
Old   September 12, 2001, 12:19
Suneesh
How to remove it? My Fluent version is 5.4.8
Old   September 13, 2001, 05:21
Volker Pawlik
I meant: ignore the warning!
Or is it impossible for you to start the solver?
As I already mentioned: I had had the warning sometime in the past. All what I remember is: The warning had no influence on solving the case.
If it is different in your case, contact your fluent office or try it with fluent 5.5.
Old   September 13, 2001, 11:07
Suneesh
In Fluent 5.5 it is working without problem
Old   September 16, 2001, 10:10
Suneesh
In Fluent 5.5 also I can't make the interface periodic. If I try it is showing BUS ERROR suneesh
Old   September 30, 2001, 04:06
Petr
Hi Suneesh,
I also experienced such warning messages with my FLUENT 5.1, but in an electronic New Feature Documentation the following procedure is proposed: grid -> modify-zones->repair-duplicate-shadows
This warning appears,I thing, when your planar zones, which you want to be periodic, are composed of several faces with common nodes, so that at least one node belongs to several faces. I use another procedure in such case: in GAMBIT I define another, but distinct types of boundary conditions on the zones which I want to be periodic, and after reading the mesh I use text commands grid->modify-zones->make-periodic
Of course, you must have as identical mesh on both zones as possible (some differences are tolerable).
I hope this could help.
Petr
Bezier-Bernstein approximation for airfoil shape DoHander Main CFD Forum 10 April 23, 2014 06:21
wall shadow rage ANSYS Meshing & Geometry 1 August 15, 2010 17:36
Wall Shadows Naghman Khan FLUENT 4 July 20, 2007 13:43
multiple shadows Nurul Murad FLUENT 1 September 28, 2001 10:35
