Multi-phase
Old   September 23, 2001, 03:52
Default Multi-phase
cehuang
HI, guys
I have a question to ask u guys.
Can Fluent model the multi-phase flow containing multi-species?
For example, i want to simulate a solution containing solvents with high volatility be deposited on a spinning disk, can i solve this question by fluent?
Thanks
Old   September 26, 2001, 12:43
Default Re: Multi-phase
Lanre
What is the mechanism of deposition? Are these droplets impinging on a spinning disk?
Old   October 1, 2001, 15:25
cehuang
NO, in this problem i assume it is already have a film coated on the disk, then rotate the disk with high speed. At the same time, the solvent contain in the film evaporating cause the viscosity of the film become hard to spread out. So i wanna use Fluent to model this situation. But i never success.
could u give me a hand?
thanks a lot.
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
using interface with Euler multi phase model karimi FLUENT 0 May 22, 2011 02:46
using interface with Euler multi phase model karimi Main CFD Forum 0 May 22, 2011 02:39
Multi phase heat exchange simulation. JP CFX 1 May 26, 2008 05:22
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
