October 4, 2001, 15:44 |
Double Precision
Hi;
I have a question. Is there any way to use double precision real numbers in user defined functions? Thanks... Ugur |
October 5, 2001, 04:33 |
Re: Double Precision
I am wondering if I have clearly understood your question. According to me, simply replace : real x; by : double x; Is that what you would like to know ? I apologize in advance if my answer is too trivial. If it is the kind of anwer you expected, I hope it might help... Best regards, Anthony |
October 5, 2001, 14:58 |
Yes, you gotteh question correctly, does double work in interpreted UDFs? Or, when your case in double precision,even if you define as real is it single or double precision. I mean, does precision of the case affect the precision of the UDF? Thanks...
October 9, 2001, 04:32 |
You don't need to do anything. Just declare your variabes as
real x; you will find that when you use double precision the Fluent header files define #define real double while for single precision Fluent defines #define real float Thus if you always use real you should have no probs. Have a look at the .h files in the /src folders under Fluent.Inc/fluent5.x/ etc. Greg |
Continuing User Defined Real Gas Model issues | aeroman | FLUENT | 6 | April 8, 2016 03:34 |
Parallel User Defined Real Gas Model | aeroman | FLUENT | 4 | July 1, 2015 06:09 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 10:38 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
