September 5, 2001, 05:05 |
meshing a spring
HOW TO MESH A SPRING ?
A SPRING is modelled in gambit. It is completely enclosed by CYCLINDER. The SPRING is subtracted from the CYCLINDER. The resulting volume has to be meshed. ( I'am not able to mesh the resulting volume by any of the schemes available in GAMBIT) |
September 5, 2001, 05:21 |
Re: meshing a spring
A) Be more specific please: you are trying to mesh a 3D spring in gambit, right ? are you trying to mesh the surface of the spring? what type of mesh ? B) Ultimately, what are you trying to do ? A spring is moving ups and down and the fluid flow characterics bcos of this ? C) For primary study, make one volume and let gambit to mesh it (do not mesh any face or age). DC
October 11, 2001, 10:24 |
Try to decompose the resulting volume in to suitable smaller volumes and try different meshing schemes with different mesh specification, if you are getting fatal error message. Actually what you are trying to analyze? Where are the inlets and outlets? Identify the areas which are giving problem while meshing and if possible try to merge edges or surfaces for better results.
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
