udf for Cd calculation
Old   November 15, 2001, 05:22
Default udf for Cd calculation
Micaela Demichela
Hi, I'm trying to use a compiled udf to change the cd coefficient used by Fluent 5.4, but the procedure written on fluent manual doesn't fit with the one described in makefile file, that, in any case, doesn't work. Someone has any suggestion for me? Thanks and best regards Micaela
Old   November 15, 2001, 09:49
Default udf information
gino
Hi!I'm a Fluent 5 user and i would to known how can to write on a file the value for a variable declaired into the UDF subroutine. Thanks and best regards. Gino
Old   November 15, 2001, 23:40
Default Re: udf information
joby
try below program , it's correctly, DEFINE_ADJUST(adj_func,domain) is calculated math equation , after the answer deliver transfer into DEFINE_SOURCE(name,c,t,ds,eqn).so DEFINE_ADJUST is subroutine , DEFINE_SOURCE(name,c,t,ds,eqn)is main program . best regards for you
#include "udf.h"
Thread *t; cell_t c;
real Yo2; real Pc; real Xo2;
DEFINE_ADJUST(adj_func, domain) { thread_loop_c(t, domain) { if( THREAD_ID(t) == 4 ) /* "4" shows your fourth floor ID */ {
begin_c_loop(c, t)
Yo2 = C_YI(c, t, 0); /* gets cell mass fraction */
Pc = C_P(c, t); /* gets cell pressure */
Xo2 = Yo2*Pc;
C_UDMI(c,t,0) = Pc*Xo2;
}end_c_loop(c, t) } } }
DEFINE_SOURCE(ff,c ,t, dS, eqn) { real source; source = C_UDMI(c,t,0)*12.; dS[eqn] = 12.;
return source; }
How can I stop the calculation in UDF Seyoung Oh Fluent UDF and Scheme Programming 1 September 24, 2013 07:44
my UDF can not calculation? happyrabbit FLUENT 0 October 21, 2010 08:59
calculation average pressure in a plane with UDF Vitalij FLUENT 1 April 10, 2007 03:39
Warning 097- AB Siemens 6 November 15, 2004 04:41
If it's right to use this UDF in DPM calculation? welch FLUENT 0 May 8, 2004 05:49
