November 8, 2001, 23:09 |
Variable wall velocity
Hi, I have a query. In fluent, there is an option for moving boundary but the velocity should be constant. Is there anyway to assign variable velocity through an UDF? Thanks
R. Sambasivam. |
November 21, 2001, 21:18 |
Re: Variable wall velocity
could you describe more what you really want to do ?
DC |
November 21, 2001, 22:23 |
Thank you for your response. See, Fluent has a provision to assign either linear or angular velocity to the wall/boundary. But this velocity should be a constant not a function of time. But I need to specify the velocity as a function of time. Say, I want to simulate a vibrating wall whose velocity varies sinusoidally. How can I approach this problem? If you can throw some light on this, I would be thankful to you. Warm regards, R. Sambasivam. |
impose oscillating wall velocity | IvanCFD | FLUENT | 0 | May 13, 2010 08:53 |
velocity inlet vs. moving wall boundary condition | Jane Leous | Main CFD Forum | 0 | September 12, 2008 12:42 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
