December 18, 2001, 13:25 |
SOx calculation
Hi I would like to modelise formation of SO2 and SO3 in a chamber of combustion I have no idea about the kinetics of reaction of the formation of SOx and therefore I don't know if I could use PDF to ontain my results?
any references are welcome thanks a lot Olivier |
December 19, 2001, 06:55 |
Re: SOx calculation
As far as I know, Sulphur is very fastly reactive, so that, I think, you can use PDF model, which is, as you know, based on 'fast chemistry'.
Sincerely, Jinwook |
December 19, 2001, 07:09 |
Re: SOx calculation
I thank you very much for your help. I will try it with PDF. thanks Olivier
December 19, 2001, 22:58 |
Re: SOx calculation
Then, would you tell me why you need sulphur modeling ? NOx generation is dependent on the combustion environment. But, as a enginnering view, it is fairly realistic to assume that all sulphur in the fuel is converted to the mostly SO2(more than 90%) and partly SO3.
January 17, 2002, 12:49 |
Re: SOx calculation
Hi JIN first I wish you the best for the new year to answer you, I am very interested to calculate SOx in order to evaluate the impact on the environment of the formation of SO3 and evaluate H2SO4.
regards olivier |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 10:37 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 09:46 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 05:20 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 09:19 |
