How to intrduceMonitoring points for XY plot?
Old   January 3, 2002, 11:09
Default How to intrduceMonitoring points for XY plot?
zahid
Hello Fellows! I need to know about introducing monitoring points on the centre line of a pipe to monitor the temperature change on those points so then i can plot those with position along pipe flow direction. In fluent 5.5 i have found XY plot along a plane but i want only the points on the center line of pipe. Guide me. Thank you.
Old   January 4, 2002, 00:00
Default Re: How to intrduceMonitoring points for XY plot?
chiseung
go "Surface-> Line/Rake" in Fluent. You can make a center line and monitor the temperature change.
Old   January 9, 2002, 12:11
Lanre
1. Create point "surfaces" (Surfaces-->Point..)
2. Use the Solve-->Monitor-->Surface to set up individual monitors for each of your surfaces. You specify the average value of the variable you want to write and specify the file-name. You can plot, print (to the console) and write your monitred values to file.
3. Review the FLUENT 5.5 Users' Guide Sections 17.15 and 17.16 for more tips
CFD-Post: Polyline Export at Integration Points minger ANSYS 4 February 22, 2014 09:23
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 23, 2012 23:41
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
plot order points... what does it means ? Cyril FLUENT 0 June 7, 2006 05:56
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
