January 15, 2002, 02:36 |
Grid problems
Hi.
In meshing my GAMBIT model I have encountered the follwing message: Impossible edge mesh/face scheme combination. Turn mesh_flags_incremental_display default on. I don't know how to turn this on, and the manual is not much help. Does anyone out there know the answer ? Christian |
January 15, 2002, 09:55 |
Re: Grid problems
go to EDIT in top left corner of screen. click on DEFAULTS click on MESH click on FLAGS radio button then set incremental_display variable to 1
January 15, 2002, 16:13 |
Re: Grid problems
First of all, this message is part of a number (3) of possible causes of failure. Usually when I get this error message I have a problem with my vertex types: for example, I want to create a mapped mesh on a face, but the vertex types are screwed up (you need 4 vertices called 'E' at logical locations to create a mapped mesh).
Check your vertex types by selecting the face, and see if they match with what you really want to do. If there is a problem, you can change the vertex to the appropriate type in the 'Set face vertex type' panel (second from the right). |
January 16, 2002, 02:55 |
Re: Grid problems
Thank you, Phil and Erwin
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
grid on a circle | HaKu | Main CFD Forum | 4 | April 15, 2010 11:56 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
"grid points" or "grid interface" | ztdep | Main CFD Forum | 1 | June 6, 2007 15:00 |
Problems in grid generation in ICEM | Tim | CFX | 1 | September 30, 2006 06:43 |
