flow pattern
Old   December 26, 2001, 11:28
Default flow pattern
chongchunleong
hi, Can FLUENT 5 simulate flow patterns such as wavy flow and slug flow for example?
Given a two-phase flow of air and water where the superficial air velocity = 5.59 m/s and superficial water velocity = 0.031 m/s, can FLUENT simulate what kind of flow pattern is it? Is multiphase VOF model or multiphase ASM model more suitable for this case?
(From theory, the flow shown in the above case should be stratified-wavy flow.)
Old   January 16, 2002, 01:16
Default Re: flow pattern
david
yes fluent can, however you need to refine the interface (if the grid is not fine enough) at every few time steps. DC
Old   January 16, 2002, 03:50
merac
How do you go about refining the interface?
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
The Effect of impeller type on flow pattern lee ji hyun Main CFD Forum 1 January 26, 2000 08:35
