compressible flow boundary conditions
Old   January 21, 2002, 10:34
Default compressible flow boundary conditions
yangqing
for compressible flow. can it lead to error that specify the inlet with vilocity inlet? i have tried a case,the residual of mass rise very fast.then disconvegence
Old   January 21, 2002, 12:10
Default Re: compressible flow boundary conditions
Karl
For compressible flow a "Mass Flow Inlet" - boundary will give you better results. For the outlet boundary use "Pressure Outlet" , but you have to be careful to set proper values for the backflow values (only needed if reversed flow occurs at the outlet).
Old   January 22, 2002, 10:19
yangqing
in my case,oulet is a mechanic fan. i only know the mass flow rate, not the pressure jump. how can i specify the out boundary condition thanks
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
boundary conditions for 3D channel flow with heat transfer Aloex FLUENT 1 February 22, 2011 12:28
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
Boundary Conditions for Incompressible Flow Bob FLUENT 0 April 7, 2006 21:28
