January 22, 2002, 10:25 |
abnormal grid in gambit
for a long tank,i want to mesh it with variable grid that is small grid for one side and large grid for other side.I meshed one edge with ratio 1.5,but it don't work.what shall do with my case?
January 22, 2002, 11:28 |
Re: abnormal grid in gambit
I have had this problem before as well, I solved it by meshing both edges on one of the faces which was to have a variable grid, then meshing that face and then the volume, not sure if this is the quickest method but it worked.
January 26, 2002, 10:10 |
i have tried meshing four edges of one volume, it's also cause mech line from one coner.why? take your ways.should i mesh the volume with the meshed face specified with source face?
grid for pipe with orifice in gambit | fofo | ANSYS Meshing & Geometry | 2 | December 2, 2009 11:33 |
export gambit grid to tecplot | ztdep | FLUENT | 1 | September 17, 2008 19:01 |
grid for lance using Gambit | star123 | FLUENT | 0 | March 23, 2006 02:38 |
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 | Isaac Manohar Ch. | FLUENT | 1 | June 2, 2000 04:58 |
Grid for Fluent v.4 using Gambit? | Ray | Main CFD Forum | 3 | October 27, 1999 12:35 |
