Gambit Meshing export to fluent minor problem
Old   February 5, 2002, 07:11
Default Gambit Meshing export to fluent minor problem
John c.
i used Gambit(using grid line,coordinate) to create my model, and i has export it to Fluent. my problem is related to dimension setting. when the meshing exported into fluent, fluent interprete 1 unit of coordinate as 1 cm, however i want my model to be 1 unit as 1 mm. what should i do? i know this sound stupid, but i really need help.
Old   February 5, 2002, 07:57
Default Re: Gambit Meshing export to fluent minor problem
Ashutosh
Use scaling after importing the data into Fluent. You can model in mm and convert that into m. You have to be careful about the units of other variables! If you are consistent in any unit then results would be consistent. Ashutosh
Old   February 6, 2002, 16:52
John c.
thank you for your advice.
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 14:21
Gambit and Fluent Help Vincent Ryan FLUENT 2 January 11, 2009 07:34
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 03:13
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
