February 20, 2002, 15:35 |
Material define
Hi, I defined a kind of new material in the material panel. Then in the injection panel, I can not find the material I deifned in the material list. Can anyone tell me how to define a new injection material? Thanks!
Chen |
February 20, 2002, 16:29 |
Re: Material define
did you press Change/Creat bottom after you define the material?
February 20, 2002, 17:22 |
Yes, I did.
Yes, I did. I can see the material I defined in the material database. But I can not see it under the material list in the injection panel.
February 20, 2002, 18:02 |
Re: Yes, I did.
I think that is due to your new material is not saved in the FLUENT database. But I have no idea about putting a local material into database.
February 20, 2002, 20:54 |
I put it in database
I did put it in the data base. But I am wondering if FLUENT is using two set of material databases.
February 20, 2002, 21:02 |
Re: I put it in database
if you only press change/creat, the data will not be put into database, it is just stored soemwhere as a local data, if you save the case, it will be stored in case file, not in database.
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
