March 1, 2002, 11:38 |
Reversed flow in ###faces on face ###
What does "Reversed flow in ###faces on face ###" mean while Fluent is calculating (Iterating)?
March 1, 2002, 11:43 |
Re: Reversed flow in ###faces on face ###
if its reversed flow on one of boundaries you have set as an output from your model: outflow, pressure outlet etc it means that in some of the faces on that boundary flow is entering the model rather than leaving it.
reversed flow on faces limited in 500 cells in region outlet | alan81 | Siemens | 0 | May 15, 2011 12:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
DPM Reversed Flow | Hendawi | FLUENT | 2 | June 5, 2002 05:01 |
reversed flow | vineet birman | FLUENT | 2 | May 8, 2002 00:58 |
