mold filling in Fluent ?
Old   April 8, 2002, 21:24
Default mold filling in Fluent ?
Tony
Hi all, 1) I tried to use the vof model in FLUENT to solve the mold filling problem in a simple 2d slot. The water inlet is from left side and right side is the outlet of the air phase, both top and bottom walls are stationary and no-slip. In this case only implict vof can give converged result but with diffused interfaces over several cells, all the other options ( donor-accetpor, or geo-construction) failed to give accurate interface shape and diverged before completely filled. Any suggestion? 2) I know that the no-slip assumption at the triple-contact point on the wall will cause the unreasonable prediction of front shape. In Flunt, is it possible to use a dynamic bounary condition?, that is in the water phase, the wall is no-slip but in the air phase the wall is outlet. Thanks in advance
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
mold filling John CFX 2 October 14, 2008 11:03
Regarding mold filling simulation in Fluent Nitin Pathak FLUENT 0 August 10, 2007 14:19
