April 12, 2002, 11:29 |
Too many vertices and faces - GAMBIT
Hello all,
I am trying to create a geometry in GAMBIT that involves subtraction of some cylinders from a rectangular box. I find that this results in the creation of hundreds of new faces. I cannot delete most of these faces because they are connected to 'upper topogical identities'. Is there any way to get rid of them? Thanks. Dhananjay |
April 12, 2002, 12:24 |
Re: Too many vertices and faces - GAMBIT
I take it you are subtracting volumes from volumes. Normally I would have expected that to work well enough in Gambit.
Delete the volumes you are left with, but keep the lower geometry (faces). You can them delete these (or perhaps healing them would be the way to go). Then build up your volume from the faces. |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 10:35 |
Gambit error: cannot select faces and volumes | smillerhh | FLUENT | 1 | December 15, 2006 09:07 |
between IDL Gambit and rhino, any help? | philip | FLUENT | 0 | June 23, 2005 12:08 |
Seperate faces from vertices | Samir | Siemens | 0 | November 29, 2004 11:16 |
