moving and deforming mesh
Old   April 14, 2002, 04:43
Default moving and deforming mesh
bonny
hello everybody
i am a candidate to doctor. i have to simulate the time-dependent movement of scroll compressor for a phd thesis.
the time-varying computational flow domain, the working chamber, is boundecd by a fixed scroll wrap, a moving scroll wrap and two apex seals. the compression process in the scroll compressor is achieved by a continuioys reduction in the volume of the working chamber. the gas is driven and compressed by the "squish motion" of the orbiting scroll wrap and , this results in an unsteady compressible viscous flow occurs within the scroll compressor working chamber.
Has anyone any idea how to solve this problem in fuent? any help would be appreciated. thanks in advance.
regards
Old   April 14, 2002, 06:58
Default Re: moving and deforming mesh
Joern
It might be easier to solve the problem than to solve it using fluent. But anyway it is not trivial to define the mesh motion. I simulated a rotary-vane-pump using starcd some years ago, which has the same requirements for the moving mesh features but an much easier way to define the movement of the verticies. There is some material about this on my home page (animation and paper from 1998 users meeting).
I think that the simulation of the screw compressor was already performed (or at least tried) using starcd or another package. I'v seen an article about a combined fluid-structure-interaction calculation of a screw pump using comet.
Old   April 14, 2002, 12:51
Anindya
Hi Joern,
Could you please let me know your home page address where I can find the moving mesh paper using StarCD?
Thanks
Anindya
Old   April 14, 2002, 18:27
jon
This will be very difficult if not impossible with fluent. Since fluent is focused on ease-of-use only and not for sophisticated analysis - it is only good for the more simpler problems.
I recommend you look at other more advanced codes like cfd-ace or starcd.
Old   April 14, 2002, 23:30
bonny
hi,
Thanks..., now i have no star-cd package or others and i do not know how to use.
Could anyone give me an example on defining the moving mesh?
And if Fluent6.0 cann't solve my problem?
Thanks in advance!
bonny
Old   April 15, 2002, 04:58
Joern
www.beilke-cfd.de
Old   April 16, 2002, 02:32
bonny
hi all
thank joern for his home page, the animation is wonderful. but i can not understand the language.do you have the paper in english? could i incorporate the user subroutine with fluent6.0 to solve the moving mesh? i know "phoenics " has this function. could anyone has the experence on this problem? i am very urgent, i need help. thanks
bonny
Old   April 18, 2002, 06:10
Joern
You find the english paper under
www.beilke-cfd.de/handout98.pdf
I did not use a subroutine but just some preprocessing commands to move the mesh. If you insist to do the simulation using fluent ask their support if it is possible.
Old   April 18, 2002, 09:16
bonny
thanks,joern. you are so kind.
Old   April 22, 2002, 23:40
bonny
hi, all i saw from the introduce of fluent6.0 that one of new features is to solve the moving and deforming grid problem. who know how to use? Thanks in advance.
bonny
Old   May 1, 2002, 12:45
  #11
riccardo
Hi!! I have the same problem!!! I need to import in fluent a deformed wing e move it while the flow is running; Someone of Fluent Help Office has told me that we can use the "User defined Function", to set the boundary condition right for the problem (in Fluent5.5 you can take a look a the Help, in the section regarding the User defined function you can find same examples...) I think than you can also write them a mail, to explain the problem (I did this way)!!
Good Luck Riccardo
Moving Deforming Mesh Riccardo FLUENT 18 June 13, 2016 09:16
domain interface for moving and deforming mesh chetan mundhe CFX 1 December 2, 2007 16:27
Moving and deforming mesh paolo FLUENT 0 June 19, 2003 08:12
udf for moving and deforming mesh xie haibo FLUENT 4 October 27, 2002 06:45
Moving / Deforming mesh Alexandre FLUENT 1 July 7, 2001 05:44
