May 13, 2002, 09:41 |
Moving Mesh and MRF
I have done an unsteady problem of a blade moving in a fluid with the moving mesh. I have also done it with MRF in steady state.
After a while, the unsteady problem with the moving mesh gives the same velocity profiles as with MRF in steady state. 1)Is it normal (I am sorry, but I don't understand very much the explanations of the users' guide)? Can I consider the MRF as the calculation is very shorter? I also did in steady state with Moving mesh, but the results aren't the same. 2)Why? Whtt's the difference with MRF? Thanks a lot for your answers |
May 16, 2002, 03:45 |
Re: Moving Mesh and MRF
if your problem is to model a single blade moving in the fluid then it is the same thing than having a fixed blade in a rotating air. So it is absolutly normal that you have the same results with moving mesh, MRF and a single rotating frame of reference. A single rotating frame would be sufficient to solve your problem and it is also the correct approach. On the other hand you can't do steady state calculation with moving mesh : it an intrisic unsteady model. Best regards |
Sliding mesh vs MRF in axial turbine simulation | Vito | FLUENT | 3 | December 21, 2011 04:57 |
moving refernce frame (MRF) vs sling mesh | sunflower | FLUENT | 0 | October 3, 2010 03:35 |
Wall boundry in MRF or Moving mesh | Amir | FLUENT | 3 | January 5, 2009 18:03 |
How to avoid walls in moving referance frame (MRF) | san | FLUENT | 5 | March 31, 2006 01:17 |
difference between MRF and Moving mesh | sharuk | FLUENT | 0 | August 25, 2005 08:37 |
